Knowledge Base Articles
QDR Clocking
QDR Clocking
Question: In the QDR SRAM should only one of the clock pair, C/C#, CQ/CQ# be used?
Answer:
Response: No, both of these clocks can be used. C and C# are the output clocks while the CQ and CQ# are the echo clocks generated by the QDRII for proper latching of data on the ASIC side.
Version history
Revision #:
1 of 1
Last update:
‎Dec 19, 2008 12:00 AM
Updated by:
Contributors
