Knowledge Base Articles
Programming the CY7C63923-XWC.
Question: When I try to program the CY7C63923-XWC using the GenProg application I get a "Can't acquire device" message in the Results column.  How do I program the CY7C63923-XWC using the GenProg application?
Answer:
To support the CY7C63923-XWC in the GenProg application you will need to replace the CY7C63900.dat file.  This file is located in the Devices subdirectory of the PSoC Programmer installation directory, normally found at C:\Program Files\Cypress MicroSystems\PSoC Programmer\Devices.
This applies to GenProg version 1.17.0.14.  The CY7C63923-XWC will be included in future releases of the PSoC Programmer application.
Version history
Revision #:
1 of 1
Last update:
‎Dec 19, 2008 12:00 AM
Updated by:
Contributors
