IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
Knowledge Base Articles
PSoC Creator Find/Replace Replaces with Literals Only – KBA21154
chaitanyav_41
Version: **
Translation - Japanese: PSoC Creatorの検索/置換はリテラルのみに置換される – KBA21154 - Community Translated (JA)
Problem: The Find/Replace option in PSoC® Creator™ replaces characters with string literals only. For instance, using the Find/Replace option to search for space characters and replace them with tab characters (‘\t’) will result in each space being replaced by the characters \t, rather than a tab.
Workaround: PSoC Creator will not be updated to support non-literal replacement of characters. Use 3rd-party editors, such as vi or Emacs to accomplish this.
Version history
Revision #:
1 of 1
Last update:
‎Oct 16, 2017 02:11 AM
Updated by:
Contributors
