Knowledge Base Articles
PSoC 1 Bootloader project: Application starting address
Question: Where should I place my application start address when using a bootloader in a PSoC 1 project?
Answer: The application start address comes after the last row of the bootloader.  Make sure to leave enough flash memory for the application code.  Is often beneficial to place one block of flash between the bootloader and the application.  See the bootloader data sheet for more information.
Version history
Revision #:
1 of 1
Last update:
‎Oct 17, 2011 12:42 PM
Updated by:
Contributors
