Knowledge Base Articles
PSC1 Pin State during a Reset in Traveo™ S6J3200/S6J326C/324C/327C/328C/32DA/ 32BA/32G0 Series MCU - KBA222234
chaitanyav_41
Version: **
Translation - Japanese: Traveo™ S6J3200/S6J326C/324C/327C/328C/32DA/32BA/32G0 シリーズMCUのリセット中のPSC1ピン状態 - KBA222234 - Community...
Question:
What is the state of the PSC1 pin during a reset? Is pull-down required on this pin?
Answer:
The PSC1 pin state is not stable if the voltage is below the operation assurance condition voltage. An external pull-down is needed if the external 1.2 V regulator requires a stable signal.
Version history
Revision #:
1 of 1
Last update:
‎Dec 25, 2017 07:31 AM
Updated by:
Contributors
