Output Impedance of CY2305 and unused outputs.
12:00 AM
- Mark as Read
- Printer Friendly Page
Dec 19, 2008
12:00 AM
Question: What is the output impedance of CY2305? What is the recommended series termination resistor value? Should I terminate an unused output?
Answer:
The output impedance for the CY2305 is between 20-30 ohm. We recommend using a 20-30 ohm series resistor to match a 50 ohm transmission line.
Ideally, you should terminate your unused output to equal your other outputs. For example, if your other output load is 15 pf, then you should terminate the unused output to 15 pf. But it is also okay to leave unused output float.
- clock distribution
Rate this article:
Contributors
This widget could not be displayed.Anonymous
