Knowledge Base Articles
Optimization level
markgsaunders
Optimization level
Question: Is it possible to achieve optimizations level above 5?
Answer:
If you have purchased the Keil CA51 Compiler Kit from Keil then you get to use optimizations above level 5. Note, however, that PSoC Creator cannot access the compiler if it is installed anywhere except C:\KEIL (the default location).
Version history
Revision #:
1 of 1
Last update:
‎Sep 03, 2009 02:29 PM
Updated by:
Contributors
