Knowledge Base Articles
On-The-Go Electrical Tester(OET) from cypress
Question: Can I get the On-The-Go Electrical Tester(OET) from CYPRESS?
Answer:
The USB On-The-Go Electrical Tester (OET) is available for purchase only through the USB-IF.
You can check the below link for your reference
http://www.usb.org/developers/estoreinfo/
Version history
Revision #:
1 of 1
Last update:
‎Oct 02, 2011 01:08 PM
Updated by:
Contributors
