Negative Resistance of CY2291 / CY2292
Question: What is the negative resistance of the crystal oscillator on the CY2291 or CY2292?
Answer:
It is designed to be at least 300ohms at 25MHz. To reduce oscillator startup issues, a crystal with an ESR of less than 60ohms is recommended.
Contributors
