Maximum Throughput Using FX2 (CY7C68013) GPIF Interface
05:24 AM
- Mark as Read
- Printer Friendly Page
Jun 13, 2011
05:24 AM
Question: What is the maximum sustainable transfer rate the FX2LP can obtain in GPIF transfer mode?
Answer:
The GPIF controller is designed to operate at a maximum IFCLK rate of 48MHz. If the external interface method is 16-bit synchronous, then a burts transfer rate of 96MByte/sec can be achieved. However, the sustainable throughput will depend on a number of factors like host controller hardware and software perfomance as well as the host application being used.
Please look at the following knowledge base article for more information on measuring host interface bandwidth.
Streaming Throughput of an FX2LP Device
Rate this article:
Contributors
This widget could not be displayed.Anonymous
