Knowledge Base Articles
Loading Code into External Code Memory (ROM)
Question: What is required to load code into a external code memory chip(ROM) that is attached to the CY7C68013A?
Answer:
The external ROM which you will be attaching to the address/data lines has to be factory programmed and then placed on the board. We cannot program it using any of the Cypress tools.
Version history
Revision #:
1 of 1
Last update:
‎Jun 29, 2009 07:58 AM
Updated by:
Contributors
