LED Backlight Support in CapSense - KBA203827
01:40 AM
- Mark as Read
- Printer Friendly Page
Oct 30, 2015
01:40 AM
Version: **
Translation - Japanese: CapSenseでのLEDバックライトのサポート - KBA203827 - Community Translated (JA)
Question:
Does CapSense support LED backlighting?
Answer:
CapSense works well with LED backlighting. A hole can be made in the sensor pad. LEDs are available in a surface mount package that are designed for backlighting (LED shines light on to board). LED traces should be kept to the bottom side of the board. If more than one LED is mounted behind each button, ensure that the active sensing area of the button has not been negatively impacted by multiple backlight holes punched out of the board.
See the Getting Started with CapSense® design guide for more information.
Labels
Rate this article:
Contributors
This widget could not be displayed.Anonymous
