How to Upgrade Firmware in HX3C
01:33 AM
- Mark as Read
- Printer Friendly Page
Apr 04, 2016
01:33 AM
USB Type-C/PD specification is continuing to evolve and the USB Type-C/PD products should continue to comply with the updated specification requirements.
Products designed using HX3C, Infineon PD Hub has the capability to comply with the changing specification requirements by upgrading the Firmware. HX3C which has in-built USB 2.0 device (Billboard function) can be configured as a bridge for upgrading the firmware through USB from Windows OS machines. Infineon provides firmware upgrade utility tool to perform the updates. For more details on the firmware upgrade tool, visit www.infineon.com/support and create a technical support case.
Labels
- ez-usba hx3c: usb type-c hub with power delivery
- hx3c
- pd
- superspeed usb hubs
- Upgrade Firmware
- USB 2.0 device
- usb type-c
- usb-c and power delivery
Rate this article:
