Heat seal paper in Capsense
Question: Can a heat seal paper be used in CapSense applications?
Answer:
The heat seal paper can be used for connecting CapSense buttons since it is a conductor and should perform as well as the metal conductor. However, it may lead to more noise as it is thin and flexible.
Contributors
