IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
Knowledge Base Articles
Factors that can impact the successful transmission of a signal from its source to destination
Question: In wireless communications, what are the factors that can impact the successful transmission of a signal from its source to destination?
Answer:
In wireless communications, instead of moving data over physical wires, it is transmitted across the air as RF energy. There are a large number of factors that can influence what happens in this channel. Here are some simple examples:
■ Attenuation due to range
■ Attenuation due to passing through objects such as product enclosures or walls
■ Multi-path effects from reflections off walls, floors, or other objects
■ Interference from other signals
All of these things impact the successful transmission of the signal from its source to its destination, and have it properly received.
Version history
Revision #:
1 of 1
Last update:
‎Apr 04, 2010 08:32 AM
Updated by:
Contributors
