FM4 ADC Usage Hardware Considerations
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Community Translation: FM4 ADCの使用上、ハードウエアの懸念点‐
In order to use ADC properly, the reference voltage (Analog Voltage Reference High (AVRH) /Analog Voltage Reference Low (AVRL)) is important. It is necessary to suppress the reference voltage swing and avoid noise on power and ground lines as much as possible. More https://community.infineon.com/t5/Knowledge-Base-Articles/FM4-ADC-Usage-Hardware-Consideration-KBA22... here.
