Knowledge Base Articles
Error message - sed: can't read HTlinkOpts.lkp: No such file or directory
Question: I am using HiTech compiler. What is the reason for the error message " sed: can't read HTlinkOpts.lkp: No such file or directory"?  How do I fix this?
Answer:
This is an issue with HiTech compiler in PSoC Designer 5.0, where it looks for a file it doesn't need and complains when it can't find that file. The problem can be fixed by placing a blank file named "HTlinkOpts.lkp" in the same directory in which .SOC file is present.
Note: This error or warning message does not come with PSoC Designer 5.0 SP5.5 onwards.
Version history
Revision #:
1 of 1
Last update:
‎Mar 27, 2011 01:48 AM
Updated by:
Contributors
