Knowledge Base Articles
EEPROM Compatibility for AT2
Question: Does the CY7C68300A use the same EEPROM as the CY7C68300?
Answer:
Yes, the 24LC02B is the recommended EEPROM for both the CY7C68300A and CY7C68300.
Version history
Revision #:
1 of 1
Last update:
‎Mar 28, 2011 02:24 AM
Updated by:
Contributors
