Differences between Part Numbers of D/A Converter in Traveo CY9D560 Series MCUs - KBA225707
10:32 PM
- Mark as Read
- Printer Friendly Page
Dec 06, 2018
10:32 PM
Author: shusakus_56 Version: **
Translation - Japanese: Traveo™ CY9D560 シリーズ MCU の D/A コンバータの部品番号の違いについて - KBA225707 - Community Translated (JA)
Question:
What is the difference between the part number options of a D/A converter in Traveo™ CY9D560 series MCUs?
Answer:
The part number option “L” or “Q” (without R/D converter) indicates that you can use the D/A converter independently. The part number option “A” or “G” (with R/D converter) indicates that you can use the D/A converter as part of the R/D converter.
Note:
The prefix MB of the product has been changed to CY. For instance, MB9D56X has been changed to CY9D56X.
Labels
Rate this article:
