Creating and/or Editing Debug Configurations
SeyhanA_31
250 replies posted 100 replies posted 50 replies posted
For versions: 2.4.0, 2.4.1 and 3.1.2
To create or edit the debug configuration click on the down arrow next to the green bug icon and select “Debug Configurations…”.
If none exist, create a new debug configuration by selecting “GDB Hardware Debugging” then selecting “New launch configuration” icon. If the debug configuration already exists, select the debug configuration you would like to update:pastedImage_8.png
Select the “Main” tab and set the selections as below:
You may update the default name as you like.  In this example the name “WICED debug” is used.
Select the “Main” tab and select a project to debug if more than one project is present.
Select the “Debugger” tab and set “GDB Command” to “<Wiced Project Dir>\Tools\ARM_GNU\bin\Win32\arm-none-eabi-gdb.exe” then set the rest as below:
Select the “Startup” tab and set the selections as below:
Select the “Source” tab and set the selections as below:
Select the “Common” tab and set the selections as below:
