Knowledge Base Articles
CMP_DATA Action – KBA90257
Version: **
Question: What role does the CMP_DATA action perform?
Answer:
The CMP_DATA action either compares the sampled address with a specified comparison value or detects any change in the data value. The message, "Repeat actions until next transition", in the state setting has no effect on the behavior of the CMP_DATA action. This action is repeated for every clock cycle.
Version history
Revision #:
1 of 1
Last update:
‎Jan 29, 2014 04:00 AM
Updated by:
Contributors
