Bad Block Management in NX2LP
09:05 AM
- Mark as Read
- Printer Friendly Page
Apr 04, 2011
09:05 AM
Question: Is Bad Block Management performed in NX2LP/NX2LP-Flex?
Answer:
NX2LP firmware does Dynamic bad block management. The firware will mark bad blocks as it runs over.
Two types of bad blocks are present, ones that come marked from the factory, and ones that the firmware marks.
When the firmware encounters a bad block while running, it marks the block as bad and replaces it with a good block from the spare pool.
Rate this article:
Contributors
This widget could not be displayed.Anonymous
