Knowledge Base Articles
AUTOPTR
AUTOPTR
Question: Is AUTOPTR only used only for moving data from/to  bulk/iso endpoints?
Answer:
No.You can write the any RAM address of the source/destination to the Autopointer register. Any access of  the AUTODATA register will result in incrementing the value stored n the autopointer register.Please see chapter 8 of the TRM section 8.8 in particular.
Version history
Revision #:
1 of 1
Last update:
‎Dec 19, 2008 12:00 AM
Updated by:
Contributors
