A typical calculation of a bootstrap capacitor’s value
Infineon_Team
The bootstrap capacitor on the high side of a gate driver provides the energy required to turn on a high-side power switch. The bootstrap capacitor discharges as the gate driver tries to turn on the high-side power switch.
The value of, the total electric charge required to turn on a power switch, is crucial. Infineon_Team_1-1713179649570.png can be expressed as:
which,
Infineon_Team_3-1713179745238.png is the gate charge,
Infineon_Team_4-1713179745240.png is the quiescent current volume responsible for supplying gate driver turn ON a power switch,
Infineon_Team_5-1713179745240.png is the volume of leakage current from the bootstrap-capacitor to the driver IC, subsequently passes to the IC’s ground,
Infineon_Team_6-1713179745240.png is the maximum duty of the frequency,
Infineon_Team_7-1713179745241.png is the operation frequency.
            Therefore, the value of the bootstrap capacitor can be derived as:
which the
Infineon_Team_9-1713179838826.png is the voltage of ripple on bootstrap-capacitor. The value of "D" can be set to "1" in order to take the margin into consideration.
In most cases, the magnitudes of
Infineon_Team_10-1713179838826.pngand
Infineon_Team_11-1713179838827.png range from a few Pico-amperes to a few nano-amperes. As a result, (2) can be approximated as,
Furthermore, the volume of
Infineon_Team_14-1713180011560.png  is generally less than or equal to 0.1V to ensure proper functioning of the high-side signal. Therefore, (3) can be expressed as,
Additionally, consider the following recommendations:
  1. Use a multilayer ceramic capacitor (MLCC) as a bootstrap capacitor.
  2. Place the bootstrap capacitor close to the driver IC with a short pathway.
  3. When determining the value of the bootstrap capacitor, consider the DC bias characteristic of the MLCC.
