230K Baud Rate Support in USB to UART Bridge Controller (Gen I and Gen II) - KBA86260
01:57 AM
- Mark as Read
- Printer Friendly Page
Mar 22, 2013
01:57 AM
Version: *A
Translation - Japanese: USB-UARTブリッジコントローラー(Gen IおよびGen II)での230Kボーレートのサポート - KBA86260 - Community Translated (JA)
Question:
Does the USB to UART Bridge Controller (Gen I and Gen II) support 230K baud rate?
Answer:
Yes, the USB to UART Bridge Controller (Gen I and Gen II) supports 230K baud rate. However, simultaneous transmit and receive operations are not supported in CY7C65225 if you select the following settings:
- Baud rate: 230K baud. This rate does not support flow control.
- Parity bit: ‘None’.
This restriction is not present in Gen II USB to UART Bridge Controller (CY7C65211/CY7C65213/CY7C65215). It is recommended to use Gen II USB to UART Bridge Controller for future designs.
Rate this article:
Contributors
This widget could not be displayed.Anonymous
