EOLDYNSKI
First question asked Welcome!
We are using the PVA30N Solid State relay to charge a high impedance ion current detector. When putting relays in series between the charge supply and the charged detector there is still significant leakage to charge the detector even  if the detector has a temporary load applied.
Is there any special concerns when connecting the reply's contact in series where both relay contact my float. Please refer to the attachedCircuit.jpg simple circuit diagram
SivaBommadevara
First like received 25 replies posted 10 solutions authored
Dear @EOLDYNSKI ,
Greetings from Infineon.
we are working on your issue.
Please allow us some to get back with an answer to your query.
Thank you.
Siva Naga Malleswararao.
SivaBommadevara
Dear @EOLDYNSKI ,
It is advisable to monitor the control current signal to verify its actual value, if it is zero, as even minimal current levels can lead to leakage on the output end.
Thank you.
