FM0+, FM3 & FM4 MCU
is there a way to use a Gigabit phy with a microcontroller or PSoC part?
I see some mentions of GMII in data sheets, but I don't seem to see any relevant pins.
Is your application is for Ethernet interface. If so, S6E2CC devices would be a good option. Please check:
http://www.cypress.com/documentation/development-kitsboards/fm4-176l-s6e2cc-eth-arm-cortex-m4-mcu-st...
bharadhwajas_91
S62ECC supports  RMII and MII for Ext PHY
Top labels
