Julius
First question asked Welcome!
The select location is obviously irrelevant. But the system didn't allow me to continue without a choice.
Can anybody suggest an easily obtainable PIN diode with good performance at 10 MHz and low power (about -30dBm)? The purpose is to switch two bandpass filters in a 10 MHz signal path. Given the frequency, the suggestion can be either SMD or a hole-through part. Thanks a lot.
AZIZ_HASSAN
50 likes received 5 likes given 250 sign-ins
Thank you for posting at Infineon community.
As per your basic requirement of operating frequency and power, we are suggesting you the following part number whose link is attached below.
https://www.infineon.com/cms/en/product/rf-wireless-control/rf-diode/rf-pin-diode/antenna-switch/bar...
However,  you might have other requirements for the filter applications as well and for that  I have attached  the link of product page where you can select the any PIN diode based upon other requirements.
Please let me know if you need any further help.
BR,
AZIZ HASSAN
AZIZ_HASSAN
BR,
AZIZ HASSAN
