JennaJo
Community Translation program details Community Translations
KBA #31 -
Translation from English to Japanese - Open
Translation from English to Chinese - Closed
Please acknowledge in this thread as a response, if you want to translate this Knowledge Base Article for the community
1. Download the attached KBA document
2. Append with your translation in the document
3. Submit the translated KBA document back as a response in this thread for review
Jenna
Jenna Jo
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear Jenna-san,
I'd like to try translating this KBA (#31)
18-Nov-2019
Motoo Tanaka
MotooTanaka
Level 9
Level 9
Dear Jenna-san,
18-Nov-2019
Motoo Tanaka
JennaJo
Hi, Tanaka-san
Thanks for your contiuous contribution.
Translation KBA has been published as below.
NAND Flash の不良ブロックの検出とマーキングについて - Community Translated (JA)
As a token of appreciation, 600 point will be give to you.
Thanks !
Jenna
Jenna Jo
