Community Translations
JennaJo
Hello, Contributors
2020 Autumn translation program is starting from Sep 1th.
For your work for AN - below 50 candidate list is prepared.
Would you pick one of below AN - and create new thread to claim your work?
Process is as;
1. Pick AN list
2. Create new Thread for claim work
3. JENA will provide machine translation version
4. Contributor will review translation version with English version, and update the translation by themselves
5. Submit and internal review is done
6. Score for work
Currently (2020.10/28) All AN candidate in this page is claimed.
Thanks for participation!
AN titleaddress
AN214821 - Upgrading Human Interface Device Firmware (Example Protocol, Commands, and Scripts)https://www.cypress.com/documentation/application-notes/an214821-upgrading-human-interface-device-fi...
AN60305 - USING PSOC(R) 3 AND PSOC 5LP IDACS TO BUILD A BETTER VDAChttps://www.cypress.com/documentation/application-notes/an60305-using-psoc-3-and-psoc-5lp-idacs-buil...
AN61904 - HOW HX2LP(TM) ADDRESSES BYTE AND WORD-ADDRESSABLE SPI EEPROMShttps://www.cypress.com/documentation/application-notes/an61904-how-hx2lp-addresses-byte-and-word-ad...
AN218238 - HARDWARE DESIGN GUIDELINES FOR EZ-PD CCG3PA IN POWER ADAPTER APPLICATIONShttps://www.cypress.com/documentation/application-notes/an218238-hardware-design-guidelines-using-ez...
AN97116 - GETTING STARTED WITH EZ-USB(R) GX3(TM)https://www.cypress.com/documentation/application-notes/an97116-getting-started-ez-usb-gx3
AN64408 - GETTING STARTED WITH NX2LP-FLEX™https://www.cypress.com/documentation/application-notes/an64408-getting-started-nx2lp-flex
AN13553- USING PROCESSOR CHIP ENABLE AS ADDRESS VALID INPUT TO ANTIOCH(TM)https://www.cypress.com/documentation/application-notes/an13553-using-processor-chip-enable-address-...
AN46860 - SCHEMATIC REVIEW CHECKLIST FOR WEST BRIDGE(R) ASTORIA(TM)https://www.cypress.com/documentation/application-notes/an46860-schematic-review-checklist-west-brid...
AN75511 - PSOC(R) 3 / PSOC 5LP - TEMPERATURE MEASUREMENT WITH  THERMOCOUPLEShttps://www.cypress.com/documentation/application-notes/an75511-psoc-3-psoc-5lp-temperature-measurem...
AN58827 - PSOC(R) 3 AND PSOC 5LP INTERNAL ANALOG ROUTING CONSIDERATIONShttps://www.cypress.com/documentation/application-notes/an58827-psoc-3-and-psoc-5lp-internal-analog-...
AN60630 - PSOC(R) 3 - 8051 CODE AND MEMORY OPTIMIZATIONhttps://www.cypress.com/documentation/application-notes/an60630-psoc-3-8051-code-and-memory-optimiza...
AN218179 - GETTING STARTED WITH EZ-PD(TM) CCG3PAhttps://www.cypress.com/documentation/application-notes/an218179-getting-started-ez-pdtm-ccg3pa
AN65231 - USB ON-THE-GO (OTG) BASICShttps://www.cypress.com/documentation/application-notes/an65231-usb-go-otg-basics
REQUIREMENTS FOR  INPUT CLOCK TO WEST BRIDGE(R) DEVICES - AN49081https://www.cypress.com/documentation/application-notes/an49081-requirements-input-clock-west-bridge...
AN49576 - INTERFACING ADMUX SRAM PROCESSORS TO WEST BRIDGE(R) ANTIOCH(TM)https://www.cypress.com/documentation/application-notes/an49576-interfacing-admux-sram-processors-we...
AN6076 - DIFFERENCES BETWEEN EZ-USB(R) FX2LP(TM) AND MOBL-USB(TM) FX2LP18https://www.cypress.com/documentation/application-notes/an6076-differences-between-ez-usbr-fx2lptm-a...
AN1215 - BASIC EMBEDDED HOST USING THE SL811HSThttps://www.cypress.com/documentation/application-notes/an1215-basic-embedded-host-using-sl811hst
AN72332 - GUIDELINES ON SYSTEM DESIGN USING CYPRESS' USB 2.0 HUB (HX2VL)https://www.cypress.com/documentation/application-notes/an72332-guidelines-system-design-using-cypre...
AN34359 - PCB LAYOUT GUIDELINES FOR WEST BRIDGE(TM) GENERATION A PERIPHERAL CONTROLLERS IN WAFER LEVEL CHIP SCALE PACKAGEhttps://www.cypress.com/documentation/application-notes/an34359-pcb-layout-guidelines-west-bridge-ge...
AN89611 - PSOC(R) 3 AND PSOC 5LP - GETTING STARTED WITH CHIP SCALE PACKAGES (CSP)https://www.cypress.com/documentation/application-notes/an89611-psoc-3-and-psoc-5lp-getting-started-...
AN42499 - DEBUGGING EZ-USB FX1/FX2LP FIRMWARE USING THE KEIL DEBUGGER ENVIRONMENThttps://www.cypress.com/documentation/application-notes/an42499-debugging-ez-usb-fx1fx2lp-firmware-u...
AN58764 - IMPLEMENTING A VIRTUAL COM PORT USING FX2LP(TM)https://www.cypress.com/documentation/application-notes/an58764-implementing-virtual-com-port-using-...
AN5033 - WIRELESSUSB(TM) DUAL ANTENNA DESIGN LAYOUT GUIDELINEShttps://www.cypress.com/documentation/application-notes/an5033-wirelessusb-dual-antenna-design-layou...
CYRF8935 WUSB-NL CHARACTERIZATION REPORThttps://www.cypress.com/documentation/reference-designs/wusb-nl-radio-driver-api-guide
AN204438 - HOW TO SET UP FLASH SECURITY FOR FM0+, FM3, AND FM4 MCUShttps://www.cypress.com/documentation/application-notes/an204438-how-set-flash-security-fm0-fm3-and-...
AN204432 - FM3, FM4 TRACE WITH μVISION AND ULINK PROhttps://www.cypress.com/documentation/application-notes/an204432-fm3-fm4-trace-vision-and-ulink-pro
AN204471 - FM4 S6E2CC SERIES EXTERNAL MEMORY PROGRAMMERhttps://www.cypress.com/documentation/application-notes/an204471-fm4-s6e2cc-series-external-memory-p...
AN205236 - FM3 MB9B500 MICROCONTROLLER WITH UART FLASH LOADER DEMONSTRATION SYSTEMhttps://www.cypress.com/documentation/application-notes/an205236-fm3-cy9b500-microcontroller-uart-fl...
AN204427 - SOFTWARE SWITCH FOR DUAL-ETHERNET FM3 MICROCONTROLLERhttps://www.cypress.com/documentation/application-notes/an204427-software-switch-dual-ethernet-fm3-m...
AN204410 - FM3 MICROCONTROLLER LOW VOLTAGE DETECT INTERRUPT CIRCUIT SETTING/USAGEhttps://www.cypress.com/documentation/application-notes/an204410-fm3-microcontroller-low-voltage-det...
AN204381 - FM3 MICROCONTROLLER DEEP STANDBY MODE SETTING/USAGEhttps://www.cypress.com/documentation/application-notes/an204381-fm3-microcontroller-deep-standby-mo...
AN204379 - FM3, INTERRUPT FACTOR VECTOR  RELOCATE FUNCTION USAGEhttps://www.cypress.com/documentation/application-notes/32-bit-microcontroller-fm3-family-interrupt-...
AN210985 - GETTING STARTED WITH FM0+ FIRMWARE DEVELOPMENThttps://www.cypress.com/documentation/application-notes/an210985-getting-started-fm0-firmware-develo...
AN204388 - GETTING STARTED FOR FM4 S6E2DH (GAT-D)https://www.cypress.com/documentation/application-notes/an204388-getting-started-fm4-s6e2dh-gat-d
AN204414 - LWIP OVER ETHERNET ON FM FAMILYhttps://www.cypress.com/documentation/application-notes/an204414-lwip-over-ethernet-fm-family
AN205399 - FM3 MICROCONTROLLER, ELECTRICAL WEIGHT ON WASH MACHINEhttps://www.cypress.com/documentation/application-notes/an205399-fm3-microcontroller-electrical-weig...
AN205354 - FM3 MICROCONTROLLER WITH OOB SOLUTION ON BLDC WASHERhttps://www.cypress.com/documentation/application-notes/an205354-fm3-microcontroller-oob-solution-bl...
AN205353 - FM3 MICROCONTROLLER WITH ELECTRICAL BRAKE APPLICATION ON BLDC WASHERhttps://www.cypress.com/documentation/application-notes/an205353-fm3-microcontroller-electrical-brak...
AN205349 - FM3 MB9AF112L/ MB9AF314L SERIES SINGLE SHUNThttps://www.cypress.com/documentation/application-notes/an205349-fm3-mb9af112l-mb9af314l-series-sing...
AN205406 - DEAD TIME COMPENSATION IMPLEMENTATION IN MB9BXXXX/MB9AXXXX SERIEShttps://www.cypress.com/documentation/application-notes/an205406-dead-time-compensation-implementati...
TROUBLESHOOTING USB 2.0 SIGNAL QUALITY - AN13632https://www.cypress.com/documentation/application-notes/an13632-troubleshooting-usb-20-signal-qualit...
AN204389 - FM0+FAMILY 3-PHASE ACIM SCALAR CONTROLhttps://www.cypress.com/documentation/application-notes/an204389-fm0-family-3-phase-acim-scalar-cont...
AN99235 - FM4 S6E2HG SERIES MCU - 16-BIT PWM USING A BASE TIMERhttps://www.cypress.com/documentation/application-notes/an99235-fm4-s6e2hg-series-mcu-16-bit-pwm-usi...
AN223616 - AFE IMPLEMENTATION USING PSOC 4https://www.cypress.com/documentation/application-notes/an223616-afe-implementation-using-psoc-4
AN2155 - PSOC(R) EMI DESIGN CONSIDERATIONShttps://www.cypress.com/documentation/application-notes/an2155-psoc-emi-design-considerations
AN205403 - INVERTER PLATFORM ROTOR POSITION FOR PMSM MOTORShttps://www.cypress.com/documentation/application-notes/an205403-inverter-platform-rotor-position-pm...
AN205344 - PI THEORY IN MOTOR CONTROLhttps://www.cypress.com/documentation/application-notes/an205344-pi-theory-motor-control
AN204878 - FM3 MB9A/BFXXX WITH FLASH PROGRAMMINGhttps://www.cypress.com/documentation/application-notes/an204878-fm3-cy9abfxxx-flash-programming
AN72419 - WEST BRIDGE(R) BENICIA(TM) HARDWARE DESIGN GUIDELINES AND SCHEMATIC CHECKLISThttps://www.cypress.com/documentation/application-notes/an72419-west-bridge-benicia-hardware-design-...
Thank you for your continuous participation to Community.
If you have any question, please response to this Thread.
Jenna
Jenna Jo
Top labels
