Apr 30, 2020
09:01 PM
Apr 30, 2020
09:01 PM
In CapSense component 'Inactive Sense Connection' parameter defined the status of sensor not being scanned, the option can be set to GND, Shield or High-Z. Once the parameter is set, it apply to all sensors. But sometimes, we want to be able to flexibly define the state of the inactive sensor according to our needs, for example, when scanning sensor0, i want sensor1 connect to shield and sensor2 connect to GND etc.
Attached project shows you how to flexibly define the state of the inactive sensor in firmware without change component generated source code.
