One day, someone sent me a message that the person is having difficulty using TCS3200 with PSoC 5.
And as I wanted to find the next theme for my sample project, I ordered a couple of TCS3200 modules to my DigKey account.
I've tried some I2C color sensors before, but "frequency" as the output(?) was my first experiment.
And also I noticed that I have not done much programming (aka hacking) with PSoC 5LP, yet.
So I gave a try v(^_^)
My schematic was something like below
The sensor has scaling choice of 0%, 2%, 20%, 100%
and color sense choice of Red, Blue, (Clear), and Green.
For the first prototype, I just let the program looping all choices, including probably nonsense 0%.
First I ran the loop with open air condition, like the picture above
Then I held an orange above the sensor
The result was
So at least the values were affected.
moto
PSoC 345 LP
Hello, work with your code in the Psoc (CY8KIT-059) modifying the sensor since the tcs3200 with which I work does not have the OE rating.
But I presented the problem that does not show me a reading result. I do not know if I'm ignoring something or declaring an incorrect function!
I attach the modified code
This shows me, without generating a measurement result of the sensor.
Dear Diego Luna-san,
I downloaded your project and re-targeted the device to my CY8CKIT-050.
And when I ran the program, same thing happened.
So I took a look at your schematic
and I found that you changed the timer period to 167.772sec where mine was 1sec.
To measure the frequency, I wanted count edges of each second.
So I changed the Timer Configure for 1sec period and checked Interrupts: On TC.
And I ran the program.
Meantime, seeing you TeraTerm screen shot, may be you are setting the new line to CR+LF,
being a Unix/Linux hacker, I prefer '\n' for a new line, but to survive in the Wintel world
I configure my TeraTerm Terminal setup as below.
New-Line > Receive > AUTO
Note: locale Japanese is not mandatory 😜
23-Jan-2019
Motoo Tanaka
thanks, change change the value in the timer, now if you throw results. thank you for sharing your practice
Today I created a version for CY8CKIT-044.
As CY8CKIT-044 can not hold two 24bit UDB counters,
I needed to modify the project to use smaller counter/timer and software ISR to handle interrupt and overflow of the counter.
BTW, I wonder why but some time, some where my brain mistook TCS3200 as TSC3200 ...
In this version, those typos were fixed (I hope).
moto
P.S. I found a bug, which adds carry out of Counter twice, and replaced the TeraTerm log and attached archive for CY8CKIT-044 with the fixed ones (4-Feb-2019)
本サンプルは CQ出版 インターフェース 2019年5月号に
ふえる今どきセンサNote
その16 RGB値を直接周波数で出力するカラー・センサTCS3200
として掲載されました。
I contributed this sample project to a Japanese technical magazine
"Interface" May/2019 edition.
moto
