CapSense & Magsense
bill
New Contributor
I have a Capsense liquid level sensor attached to plastic container that is 3 mm thick.   With this setup I do not see any change in signal when water is added.  What is the maximum wall thickness that this sensor will work?   is it possible to increase the sensitivity?
Hari
Hi @bill
You can use the 12-Rx strip of the 022 kit for evaluation. Please make sure that you connect both the Tx sensors to ground so that you obtain maximum coupling with ground in the design.
Hari
