What tools or applications notes are available to help customers convert their MBR2 designs to newer sensing technologies?
I don't see CY8MBR2044 support in EZ-Click SP 2.0, which implies I won't be able to import a design from MBR2 specifically for the 2044 then convert it to a similar MBR3 such as the CY8MBR3018-LQXI.
Beyond software conversion, there appears to be differences in voltage.
What other key considerations are there?
Is there a more compatible path from MBR2 to a PSoC chip rather than MBR3?
Greg
Hi GrCa_1363456
CY8CMBR-2044 is not an I2C configurable device and hence, the reason for exclusion from EZ-Click. The parameters such as FSS and auto reset are detected from voltage levels on GPO pins and not from a configuration register as in the case of MBR3.
MBR3 is more versatile compared to 2044.
This supports configuring the parameters through I2C. Hence, they can be changed during run-time by a host as well.
The voltage levels are same in both devices. CY8CMBR3002 is a similar device that does not support configuration over I2C. However, this supports only 2 CapSense sensors.
We recommend to use the PSoC series of devices as it supports manual tuning and a wider operating conditions. It can also run as a standalone microcontroller.
Hari
Hi GrCa_1363456
Hari
