Hi @weixiaohalou ,
I suppose you are referring to the EVAL_PASCO2_SENSOR2GO
For further details on the measurements, please refer the Reference Design section in https://www.infineon.com/cms/en/product/sensor/co2-sensors/ . Do let us know if you have any other queries on the same.
Deepa
Hi @weixiaohalou ,
What bug are you referring to? Regarding dimensions, yes they are given in mm.
Deepa
But I measured the sensor with a ruler, its size is about 3.3 cm long, 3.1 cm wide and 2.2 cm high, which does not match the manual
Hi @weixiaohalou ,
Deepa
