CAPSENSE™ & MagSense Forum Discussions
bill
I have a Capsense liquid level sensor attached to plastic container that is 3 mm thick.   With this setup I do not see any change in signal when water is added.  What is the maximum wall thickness that this sensor will work?   is it possible to increase the sensitivity?
Hari
Moderator 750 replies posted 500 replies posted 250 solutions authored
Hi @bill
You can use the 12-Rx strip of the 022 kit for evaluation. Please make sure that you connect both the Tx sensors to ground so that you obtain maximum coupling with ground in the design.
Hari
Hari
Hello @bill
Can you give us more information on the liquid that you are trying to sense? Is it conductive or non-conductive liquid? Is the liquid grounded or un-grounded?
What sensing method are you using? Is it CSD or CSX?
Using CSD method, with sufficient ground coupling, sensing the liquid would be possible. Please let me know the height of the container (where the liquid is present) and the number of sensors that are used.
Hari
bill
The liquid is water.  Height is 0 to 150 mm.   Currently it is ungrounded.   I am using the CY8CKIT-022 evaluation kit with the 12 sensor strip.
Hari
Hi @bill
Hari
