CAPSENSE™ & MagSense
Lepus_digitalis
New Contributor
Dear Sirs,
We are facing problems with availability of CY8CMBR3108-LQXIT on the market. The current design construction was based on this chip. Are there any "similar" chip-products available in your portfolio which has better availability and after some redesign works can be utilized in cicuit ?
Thank you for support in advance !
ncbs
Hi @Lepus_digitalis,
Based on your requirement, check the ordering information section of the MBR3 datasheet and select a suitable MPN.
PSoC 4000S provides cheap solution for CapSense applications - https://www.cypress.com/file/230631/download
For chip availability information, please contact sales - https://www.cypress.com/about-us/sales-offices
Nikhil
ncbs
Nikhil
