Bluetooth SDK
AlPr_4646536
New Contributor II
Hello.
I'm using modus toolbox to make an application with the evaluation kit CYW920819-EVB-02.
In the application I need to use the log() function included in the math.h library.
even if I include the math.h library when the program compiles gives this error:
How do I fix this mistake?
thank you so much
AnjanaM_61
Hi AlPr_4646536 ,
Math functions are not supported in MTB for 20xx devices. Only for PSoC its available.
Anjana
