Bluetooth SDK Forum Discussions
marzuniga845
Hello all,
I have the CYBT-213043-MESH kit, and I have the CY8CKIT-005 MiniProg4 Program and debug kit.
I have connected the debugger (SWDIO pin) to the mesh kit (SWDCK pin) while both connected to my Mac.
I have set the ENABLE_DEBUG?=1 in the appropriate makefile of the application I wish to download onto the board.
My problem is that when I try to launch the debug, I get this error:
Started by GNU MCU Eclipse
Open On-Chip Debugger 0.10.0+dev-4.2.0.1430 (2021-03-05-16:23)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
adapter speed: 10000 kHz
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
cortex_m reset_config sysresetreq
force hard breakpoints
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : CMSIS-DAP: SWD  Supported
Info : CMSIS-DAP: JTAG Supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : KitProg3: FW version: 2.21.1005
Info : KitProg3: Pipelined transfers enabled
Info : VTarget = 0.000 V
Info : High speed (adapter speed 10000) may be limited by adapter firmware.
Info : clock speed 10000 kHz
Error: DAP 'CYW20819A1.cpu' initialization failed (check connection, power, transport, DAP is enabled etc.)
Info : CYW20819A1.dap: powering down debug domain...
Warn : Failed to power down Debug Domains
I would appreciate the help on how to proceed!
DheerajPK_41
Moderator 750 replies posted 500 likes received 500 replies posted
I will try to reproduce the issue. Please let us know the Modustoolbox and BTSDK versions which you are using.
Also, could you please let us know why do you need to use this hardware debugger on Meshkit? If you are trying to debug a mesh application, we suggest you to use the puart logs/btspy logs. Also you can enable below traces from the application to get various levels of debuggin traces.
MESH_MODELS_DEBUG_TRACES ?= 0
MESH_CORE_DEBUG_TRACES ?= 0
MESH_PROVISIONER_DEBUG_TRACES ?= 0
-Dheeraj.P.K
DheerajPK_41
As mentioned in the error message, first check the connection from your Miniprog4 to the BT kit. May I know which all pins you connected to the minirpog? Also, check whether the board is provided proper power supply also.
-Dheeraj
marzuniga845
Hi Dheeraj,
I connected Pin P12 on the board to Pin SWDIO on the miniprog. I also connected both grounds together.
Mariela Zuniga
DheerajPK_41
-Dheeraj.P.K
marzuniga845
Hi Dheeraj.P.K
I am using ModusToolbox version 2.3.0.2307. This is the hardware debugger compatible with the CYBT-213043-MESH device. I have made additional connections: VDD(on device) to Vtarg (on the debugger), and SWCLK (on debugger) to P12 (on device). However, I am still getting the same error.
If I were to use the puart logs or btspy logs, where would I find them?
DheerajPK_41
You can refer below blog to understand how to enable btspy logs. In mesh I hope you just have to route the debug logs to to WICED_UART instead of puart using API wiced_set_debug_uart(). By default debug logs are routed to PUART. You can use any terminal emulator program (Eg. Teratem, putty, etc.) to get the logs. Connect it to PUART COM port to get it.
https://community.cypress.com/t5/ModusToolbox-Blog/How-to-enable-BTSpy-traces-in-your-BTSDK-applicat...
-Dheeraj.P.K
marzuniga845
I found your resource helpful. However, I am still having trouble connecting Cypress MiniProg4 hardware debugger to my CYBT-213043-MESH 02 kit. If I were to want to stick with hardware debugging rather than solely relying on the btspy logs, what recommendations do you have to get the right connections?
(I am still getting this error:
All the best,
Mariela Zuniga
