Bluetooth SDK
kmantem
New Contributor II
We are working to integrate a CYW20719 chip with a NAND Flash memory chip from Micron.
Could you please point us to a code example/library we can use to read/write files to this chip?  We are having a hard time figuring out how to program it with the WICED SPI API or use SPI2 with the WICED Serial Flash interface.  As this is a multiple SPI (Quad SPI) are there any examples on how to do this on this specific chip?
Thanks in advance
BragadeeshV
Hi @kmantem ,
There is no driver support for Quad SPI in CYW20719B2. Please check the BTSDK 3.0 technical brief where this is documented.
https://community.cypress.com/t5/Resource-Library/AIROC-Bluetooth-SDK-3-0-Technical-Brief/ta-p/28155...
Please contact your local sales representative or the marketing team for further details.
Bragadeesh
BragadeeshV
Hi @kmantem ,
Bragadeesh
