Programming Error - CYBT-213043-02 device on CYBT-213043-EVAL over UART without using USB-Serial converter
vigb_1229181
First comment on KBA 5 replies posted Welcome!
I am trying to program CYBT-213043-02 device on CYBT-213043-EVAL bypassing USB-Serial converter using SW4. Following is the error during programming.
= Build complete =
Begin post build processing
hex file already exists
hex file is newer than elf, skipping post-build operations
make clean to refresh hex if needed
Programming target device ...
Detecting serial port ...
Found serial port : COM1
Downloading FW ...
Launch minidriver at 0x00270400 failed
Download failed
If you have issues downloading to the kit, follow the steps below -
Press and hold the 'Recover' button on the kit.
Press and hold the 'Reset' button on the kit.
Release the 'Reset' button.
After one second, release the 'Recover' button.
make[1]: *** [../wiced_btsdk/dev-kit/baselib/20819A1/make/recipe/program.mk:102: qprogram] Error 1
make: *** [../wiced_btsdk/dev-kit/baselib/20819A1/make/core/main.mk:350: secondstage] Error 2
Modus Toolbox version - 2.2 ( error is same in version 2.1)
I have cleaned and built the project and followed recovery instructions, but the error is same.
All the hardwire connections are proper and they are working. Ihave tested their functionality before conencting to Eval kit.
The BLE module is working because it gets programmed thru' USB-Serial converter.
Kindly support in resolving this issue.
regards,
Vinay
DheerajPK_41
May I know how did you bypass USB-Serial converter(sw4)?
Please try to download the app using chipload tool as said in https://community.cypress.com/docs/DOC-18139, and let me know what is the result.
I would suggest you to try downloading the application to a fresh new board.
-Dheeraj
DheerajPK_41
-Dheeraj
