Hi
I am using cyw20706 on MudusBox SDK
I used memcmp to compare array and string
But, when I compare "AT+IOSSERIAL" and "AT+IOSTEAMID", memcmp return 0.
"AT+IOSSERIAL" and "AT+IOSTEAMID" are different.
why are you doing this
I tested the hal_gpio demo about the API, there is no problem.
The code snip is as follows:
APPLICATION_START( )
char test1[] = { 'A', 'T', '+', 'I', 'O', 'S', 'S', 'E', 'R','I', 'A', 'L' };
char test2[] = { 'A', 'T', '+', 'I', 'O', 'S', 'T', 'E', 'A','M', 'I', 'D' };
uint8_t com_result;
wiced_set_debug_uart( WICED_ROUTE_DEBUG_TO_PUART );
wiced_hal_puart_select_uart_pads( WICED_PUART_RXD, WICED_PUART_TXD, 0, 0);
WICED_BT_TRACE( "GPIO application start\n\r" );
wiced_bt_stack_init( sample_gpio_app_management_cback,NULL,NULL);
if(memcmp(test2, test1, 12) == 0)
WICED_BT_TRACE("strings are same\n");
else
WICED_BT_TRACE("different strings\n");
And the log is :
different strings
sample_gpio_app_management_cback 21
sample_gpio_app_management_cback 0
gpio_test_led
uint8_t com_result;
else
And the log is :
different strings
gpio_test_led
