I just received a CYBT-213043-EVAL board.
I'm already stuck at the getting started part of the ModuleToolBox IDE User guide (https://www.cypress.com/file/455211/download )
The CYBT-213043-EVAL board is not available in the New Application menu. It seem also not even possible to import example project from GitHub - cypresssemiconductorco/Code-Examples-BT-SDK-for-ModusToolbox: These examples demonstrate th...
Did I miss somethings ? Is there another quick start guide ?
Simon
ispn:40213:1:0
l1:314:1:0
Hello Simon,
We have Modus Toolbox installation guide available- https://www.cypress.com/file/455216/download
Also, can you update your BT SDK to version 1.4?- ModusToolbox BT SDK 1.4
Let me know if this resolves your problem.
FYI - https://www.cypress.com/products/modustoolbox-software-environment
Hello Simon,
Hello Sheetalj
Thanks for your reply. I'm now able to build and execute an example.
You should considere to update the gettings started guide.
Also I can't find the Knowledge base article KBA226703 mentioned here :
Simon
Hello Simon,
You do not need platform files for CYBT-213043 board; it is already supported in Modus Toolbox.
The mention of KBA on board page is a mistake, thanks for pointing out.! I will initiate a process internally to correct this.
