ChCh_3584941
Level 4
Level 4
50 sign-ins 25 replies posted 25 sign-ins
Working with the CYW20719B2 chip / ModusToobox.
Is there a way to erase the application code from the internal flash (using the IDE or some other tool), so that the chip is back to it's 'Factory' state?
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi ChCh_3584941
One way would be to program the device with an empty application. This will overwrite your previous application in the flash.
We also have an API wiced_hal_sflash_erase() which can be used to delete particular bytes in the flash. Please check wiced_hal_sflash.h for more details.
Also, you can try using 'Erase' option in Cypress Programmer.
SheetalJ
Hi ChCh_3584941
