Hi there,
Apologize if the question is too green, lately I was testing with wiced_bt_set_local_bdaddr(), wiced_bt_mesh_core_get_local_addr() and wiced_bt_ble_observe() just to make sure that I can scan that the mesh device nearby based on mac address. Somehow ... even though I set the mac address to make it easier to "spot" it while scanning with wiced_bt_ble_observe(), it seems I still cannot find my device.
- Is it not possible to scan with wiced_bt_ble_observe() after it is provision ?
- I also read on the log that the "adv is stop" after it is provisioned ... is it related with this ?
- is there a way to scan mesh device ?
Thanks and Best Regards,
LUTHFI AD
- cybt-213043-mesh
1) 2) Yes, Since adv is stopped, you cannot scan and get the device.
3) May I know the use case? Could you please explain?
As per the spec,
"a unique Bluetooth BD_ADDR is not required for mesh operations. Instead, each node shall be assigned a 128-bit UUID known as the Device UUID. Device manufacturers shall follow the standard UUID format as defined in [8] and generation procedure to ensure the uniqueness of each Device UUID"
This UUID is generated during the initialization of the app. Please check mesh_application.c.
-Dheeraj
As per the spec,
-Dheeraj
Ok, thanks.
