Bluetooth SDK
FeTa_4356966
New Contributor II
Hello~
I use modustoolbox to develop CYW920706WCDEVAL, but I cannot see the "device configurator" tool.
How can I use it to allocate I/O?
Charles_Lai
The BSP of TARGET_CYW920706WCDEVAL in wiced_btsdk doesn't provide the component bsp_design_modus and the file design.modus.
You may need to configure the GPIO in the traditional way by coding.
Charles_Lai
1) Open ModusToolbox.
2) Pick one of your projects and click on it, in Project Explorer. The project should be a PSoC or WICED project.
3) Wait for Quick Panel to refresh. This step should be really quick and you can't feel it.
4) Device Configurator will now appears in Quick Panel. Choose it.
Sincere regards from​ C. L.
FeTa_4356966
New Contributor II
ModusToolbox v2.1 uses CYW920706WCDEVAL without this tool.
Charles_Lai
I also confirmed that HAL-20706WCDEVAL.gpio doesn't activate the option "Device Configurator" in Tools collection.
But if you try other code examples, you should find it working.
FeTa_4356966
New Contributor II
Will the revision improve?
How to configure I/O?
Charles_Lai
