How can I connect a wide-band headset to the CYW20719?
AlGo_4347736
10 replies posted 10 questions asked 5 replies posted
Hello!
I use an example from the AG library and I can't connect a wide-band headset to my application.
Narrow band headsets work fine - there is audio.
But when I connect the wideband - there is no audio.
Would you like to see if I am using the wrong settings? Or the chip simply does not support the wideband?
* Create SCO connection as an originator or an acceptor
void hfp_ag_sco_create( hfp_ag_session_cb_t *p_scb, BOOLEAN is_orig )
    //wiced_bt_dev_status_t   status;
    wiced_bt_sco_params_t   params = hf_control_esco_params;
    /* remove listening SCO */
    if ( p_scb->sco_idx != BTM_INVALID_SCO_INDEX )
        wiced_bt_sco_remove( p_scb->sco_idx );
    /* Attempt to use eSCO if remote host supports HFP >= 1.5 */
    if ( is_orig )
        if (p_scb->retry_with_sco_only)
            p_scb->retry_with_sco_only = WICED_FALSE;
            params.packet_types        = BTM_SCO_LINK_ONLY_MASK;
        else
#if (BTM_WBS_INCLUDED == TRUE)
            if ( p_scb->peer_supports_msbc && !p_scb->msbc_selected )
                /* Send +BCS to the peer and start a 3-second timer waiting for AT+BCS */
                hfp_ag_send_BCS_to_hf (p_scb);
                wiced_start_timer (&p_scb->cn_timer, 3);
                return;
            /* If WBS is negotiated, override the necessary defaults */
            if ( p_scb->msbc_selected )
                params.use_wbs        = WICED_TRUE;
                params.max_latency    = 13;
                params.retrans_effort = BTM_ESCO_RETRANS_QUALITY;
                params.packet_types   = ( BTM_SCO_PKT_TYPES_MASK_EV3     |  /* EV3 + 2-EV3 */
                                        BTM_SCO_PKT_TYPES_MASK_NO_3_EV3 |
                                        BTM_SCO_PKT_TYPES_MASK_NO_2_EV5 |
                                        BTM_SCO_PKT_TYPES_MASK_NO_3_EV5 );
                BT_Trace(BT_RES_WICED_USE_WBS);
            else
                BT_Trace(BT_RES_WICED_USE_NBS);
#endif
            /* Igf setup fails, fall back to regular SCO */
            p_scb->retry_with_sco_only = WICED_TRUE;
        wiced_bt_sco_create_as_initiator( p_scb->hf_addr, &p_scb->sco_idx, &params );
    else
        wiced_bt_sco_create_as_acceptor( &p_scb->sco_idx );
    WICED_BT_TRACE( "hfp_ag_sco_create  is_orig: %u   sco_idx: 0x%0x  status:0x%x retry_with_sco_only: %u\n",
                    is_orig, p_scb->sco_idx, status, p_scb->retry_with_sco_only );
AlGo_4347736
A small clarification for the question:
Narrow band headsets work fine - PCM is sent off the chip.
But when I connect the wideband  - PCM is not sent off the chip.
Hi AlGo_4347736​,
The clock settings for both narrow band and wide band are different. Please check PCM/I2S Clock setting in CYW20706  for details on the same.
Thanks! I saw this document.
"This is taken care by the WICED Stack. You just need to enable or disable WBS in the application project" - This is what was done.
I get here by the logs:
Or do you have to change the frequency? How can I do this?
Setting pins:
   wiced_hal_gpio_select_function(WICED_P04, WICED_PCM_CLK_I2S_CLK);
   wiced_hal_gpio_select_function(WICED_P07, WICED_PCM_OUT_I2S_DO);
   wiced_hal_gpio_select_function(WICED_P10, WICED_PCM_IN_I2S_DI);
   wiced_hal_gpio_select_function(WICED_P06, WICED_PCM_SYNC_I2S_WS);
Configure the PCM like this:
wiced_hal_pcm_config_t pcmConfig;
memset(&pcmConfig, 0, sizeof(pcmConfig));
pcmConfig.mode = WICED_HAL_PCM_MODE;
pcmConfig.role = WICED_HAL_PCM_MASTER;
pcmConfig.pcm_param.fillData = WICED_HAL_PCM_FILL_0S;
pcmConfig.pcm_param.frame_type = WICED_HAL_PCM_FRAME_TYPE_SHORT;
pcmConfig.pcm_param.lsbFirst = WICED_HAL_PCM_MSB_FIRST;
pcmConfig.pcm_param.rightJustify = WICED_HAL_PCM_ENABLE_RIGHT_JUSTIFY;
wiced_hal_set_pcm_config (&pcmConfig);
With the logic analyzer we have seen that the PCM bit-clock and frame-sync is generated as expected by the BT-chip also in wide-band. PCM samples are also transmitted from the codec to the BT-chip correctly. But for some reason the samples are coded and sent from the BT-chip to the headset. No pcm samples coming from the BT-chip can be seen on the bus. Probably something is missing in the PCM routing inside the BT-chip or codec negotiation with the headset.
