Bluetooth SDK Forum Discussions
DaCo_1519921
Hi all!...after downloading and successfully installing the Modus Toolbox IDE I am having trouble to connect my Windows-10 pc with the Cypress EZ-BT MESH EVALUATION KIT...SEEMS MY COMPUTER IS UNABLE TO LOCATE THE RIGHT USB SOFTWARE DRIVER: not on my pc nor the Internet.
Any one have had the same issue/s before?...and then succeeded in solving it/them??....
Thanks in advance for any help and/or suggestion/s in this regards!
Daniel Corte.
VictorZ_46
5 comments on blog 25 sign-ins 250 likes received
On my PC, when I plug in the mesh kit, there is a USB-Serial (Dual Channel) with yellow bang. But also 2 new COM ports (WICED HCI UART and WICED Peripheral UART). If you have the same behavior, just ignore the yellow bang. 2 COM ports is all you need.
VictorZ_46
