Bluetooth SDK
LiLe_3234306
New Contributor II
Hi Cypress,
As I know, MBT 2.2 and BTSDK 2.8.x supports for BT Core 5.0.  But our customer wants to receive BT Core 5.2 with CYW20706 for BT SIG certification because it's listed as BT 5.2 in BT SIG.
When I check the air log using MBT 2.2 and BTSDK 2.8.x, it's shown as BT Core 5.0. Please see the attached air log.
Q) To receive BT SIG certification with BT Core 5.2, what should we do?
Liam
LiLe_3234306
New Contributor II
Hi MichaelF_56,
Thanks again for your confirm.
I have opened mycase#00611475, could you check it?
Liam
MichaelF_56
What is needed from BT 5.2?
Note that the CY-WICED 4.1 BLUETOOTH Host Stack (BT5.2) listing is complete.
Below are the details.
  • DID #  D050754
  • QDID # 160340
LiLe_3234306
New Contributor II
Hi MichaelF_56,
About your question - "What is needed from BT 5.2?",
Our customer just wants to get BT SIG approval with BT 5.1 or BT 5.2 for their product.
Q) Could you let me know the WICED SDK version used to CY-WICED 4.1 BLUETOOTH Host Stack?
Liam
MichaelF_56
ModusToolbox Bluetooth SDK 2.8
LiLe_3234306
New Contributor II
Hi MichaelF_56,
As you said, if ModusToolbox Bluetooth SDK 2.8 uses CY-WICED 4.1 BLUETOOTH Host Stack, BT Core version information should be shown as BT Core 5.2. Rigth?
However, when I check OTA log using the MTB & BTSDK 2.8, BT Core version is shown as BT Core 5.0. Please see the attached image in 1'st post.
Let me check it again and then update soon.
Liam
LiLe_3234306
New Contributor II
Hi MichaelF_56,
This is Liam Lee working for Uniquest(Disty. in KR) as FAE. If you are ok, I'd like to keep talking this case via mycase. If so, let me open mycase and then let you know the mycase#. Are you ok?
Liam
MichaelF_56
Sure.  One of our SW AEs will need to answer the OTA mismatch issue.  Our Stack noted above is BT 5.2 certified with all the necessary patches.  This is the stack used in ModusToolbox Bluetooth SDK 2.8
LiLe_3234306
New Contributor II
Hi MichaelF_56,
Liam
