CYW20819 i2s microphone to a2dp
MaCh_4826131
25 sign-ins 10 sign-ins 5 questions asked
I have a microphone connected to my CYW920819 board via i2s.
Unfortunately I am unable to get it to stream to my bt headphones via a2dp (is it even possible?)
I am using the watch example for this board and followed the blog below to route i2s.
https://community.cypress.com/t5/Resource-Library/PCM-I2S-Clock-setting-in-CYW20706/ta-p/246335?emcs...
Could it be a codec issue/sampling rate issue?
Any help would be greatly appreciated.
Thanks in advance!
Hi @MaCh_4826131 ,
Apparently I2S input feature on watch CE is supported only on CYW20721 platform. It is not possible to receive input using a microphone via a codec on CYW20819 over I2S.
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi @MaCh_4826131 ,
Audio over I2S is supported by CYW20819 using SBC codec. However, it only supports upto 16kHz frequency.  This is mentioned in datasheet section 7.11 I2S Interface-
The clock rate in master mode is as follows:
■ 16 kHz × 16 bits per frame = 256 kHz
Please note that CYW20819 can only be used in audio source mode. A note clarifying this is mentioned in datasheet- Only audio source (other than SCO) use cases are supported on CYW20819.
Thank you for your reply!
I have used   wiced_audio_start(WICED_FALSE, AUDIO_ROUTE_I2S, lcid, &av_app_cb.sbc_caps_configured);
and have even tried configuring the GPIO pins using  wiced_hal_gpio_select_function(WICED_P12,WICED_PCM_CLK_I2S_CLK);
However i am unable to listen to any input from the microphone still using a2dp on my bt headphones. Is there a step I am missing?
Thanks!
P.S. I have tried putting it in master mode by setting wiced_audio_start(WICED_TRUE, AUDIO_ROUTE_I2S, lcid, &av_app_cb.sbc_caps_configured);
but I am unable to get a clock reading from the pinout on an oscilloscope.
Are you able to test watch example successfully? It uses audio over I2S only right. Can you check the implementation there once?
Yes I tested the watch example, however, i2s input is blanked out. I found out that CYW9BT_Audio is not defined and therefore does not include wiced_audio_manager.h
Could this be the problem? I have reinstalled the audio library using library manager but it seems to still not be included in the project file.
Do I need to install wiced_audio_manager.h somehow ?
Hi @MaCh_4826131 ,
